My 2015 Mazda 6 had about 4800+ miles on it when I had the dealer do the first oil change. I moved to Phoenix a while back and purchased the car new here. While I would normally, always, do oil/filter changes myself, the dealer gave me the first change free. Because it is dusty here in AZ and temperatures vary greatly, a OCI of either 4 months or 5K miles be adhered to. The dealer invoice stated they used Castrol Edge 0W-20. I know Mazda is adamant about recommending the Mazda-branded oil as it has lots of Moly in it. I'm not concerned but they did over-fill the crankcase by a good 1/2" over the top mark on the dipstick. A veteran mechanic friend of mine said it is not enough to cause an issue - frothing, etc.
What are others with the Skyactiv engines using in their vehicles? I assumed that because the engine uses such a high compression ratio, 13:1, that using the proper oil is crucial. Thanks.
-Marc
-Marc
