2015 Caravan radiator leak
Canuck - moved to —> California —> Texas —> ???
This is for my 2015 Grand Caravan.
I noticed coolant smell and the ovreflow bottle was at the minimum mark.
I see coolant just below the upper radiator hose plastic connection, the hose connection definitely is not leaking. Seems to be the plastic mount and it all drips down the side.
I don’t yet know how fast I’m loosing coolant, so I’m going to keep an eye on it.
In the meantime I’m looking at radiators. RA shows these. Mopar would be a no-brainer provided it’s shipped without damage, should I consider others?
I had luck with Denso for my sister’s Highlander about 5 years ago. There were some obvious differences between that and OEM, i think some fin count or whatnot. Did the job though quality wise.
You should consider others.
TYC isn't no-name and is what I'd go with. But if you want to spend more and feel fuzzy get the Denso.
When you see how they're made, they've got the process down. Mopar won't be better.
