- Joined
- Aug 3, 2024
- Messages
- 72
The pedal moves almost half of its travel before any braking takes place, push it hard enough and it will bottom out. Replaced the master cylinder twice, tried a used but working ABS module, replaced rubber hoses with braided stainless, and bled about a gallon through the system in accordance with the service manual first using a Motive pressure bleeder then speedbleeders at each wheel. Pads and rotors are fine and the calipers move freely. I even tried bleeding immediately after activating the ABS on a gravel road. No change in any way, the pedal travel is still excessive. Oddly enough, with the engine off and the booster bled down, the pedal is rock hard. The pedal adjustment seems OK.
Mind you I've never much liked the brakes on this thing, but I don't remember them ever being this bad (my wife uses it as her daily, I rarely drive it). I'm totally out of ideas, is there something I missed? TIA.
