2014 Infiniti QX80
Hello all. I have a 2014 Infiniti QX80. The brake light (BRAKE) and battery light flash every time I slow down. I just had the alternator replaced a month ago, when this first happened. Ideas?
Did you have the battery tested too?
otherwise a short in the battery switch or some wiring issue?
are the battery terminals tight can you move them by hand at all?
typically what you are experiencing would be a possible bad alternator.. was it replaced with OEM? any sort of testing done on it?
I believe it was replaced with OEM. Before I had the alternator replaced I had it, and the battery tested. I was told, the battery was good, and the alternator regulator was bad…….
I just had the battery and alternator tested. They are both good. Any ideas will be greatly appreciated
