gathermewool
Site Donor 2025
Based on another post, I decided to pull my MAP sensor (PRESSURE sensor, to be clear) in my 2014 Forester XT, which is installed directly atop the intake manifold, aft. It was coated with a very thin film of a very dark, oily like substance that had a 3D geometry (it stuck out from the bulb) A spritz of MAF cleaner from each of the four axis had it looking like new.
I've never seen a MAP sensor that looked, well, kinda like a MAF sensor. Any thoughts?
I forgot to grab a pic and will do so when I get the chance, but here's a dirtier example from another FXT:
Now that I think about it, I also forgot to add a dab of dielectric grease to the connector, which I do any time I take one apart.
P.s., the MAP sensor in my '15 Legacy 2.5 (non-turbo) is located in the same exact location, but appears as a normal MAP sensor of old, except it dips into the intake manifold, too, instead of having a vacuum tube attached to it.
