2013 Buick Lacrosse cx Hybrid stalls at stop signs
Wisconsin
These 2.4 hybrids seem to be abundantly available for $1500 or so but many have issues with stalling at stops and high miles -150k+.
They usually say they need a new hybrid alternator.
How likely is it to get GM to cover this under the recall?
How likely is just throwing the part at this to actually fix it?
Once they start stalling isn’t it usually a combination of problems including oil consumption, compression, plugged egr, and the hybrid control module.
With clean sheet metal it’s tempting, many decades ago my father bought a clapped out 4 banger car (the 4 cylinders were always failed) and the mechanic was able to drop in a full v6 motor and transmission with everything left bolted together then wired it up relatively cheaply.
Not sure if that’s possible now that everything is bespoke and disposable.
If it's difficult to get rolling from a stop it's a hybrid problem such as the hybrid battery. A hybrid isn't supposed to run the gas engine much at all in stop and go driving.
These have a specific defect that they “stall “ when they aren’t supposed to shut off the engine. Being a mild hybrid the engine needs to spin while you are moving.
This is usually during braking when the motor is supposed to keep spinning to recharge the battery
When the engine stalls it’s then hard to restart from a stop or if it stalls and you don’t fully stop you obviously can’t accelerate.
