2012 Yukon steering rack bushing play
2012 Yukon 1500, Original rack with 140K miles, have some play in the steering rack but unsure what is acceptable. This video was taken with one wheel off the ground, seems to have a good bit of play, don't see any cracking in the rubber.
Can I just replace the bushings? Also, I just had this aligned a month ago..grr., if I have to remove the rack to replace bushings, are these tie rod ends ok to remove from knuckle and return without affecting the toe? Will the rack hang down enough to use C-press with tie rod ends connected to change bushings if needed?
