Morning BITOG
Defendant: 2012 Sonata 2.4L
Plaintiff: My Sister
Complaint: Aggressive Throttle Tip-In
Presiding Judge: The Honorable Backyard DIY’er
Defendant is confirmed by myself to have excessive throttle tip-in. For a 2012 Sonata 2.4L this thing bolts off the line and will smoke those front tires like a hippie at Woodstock. I drive a Genesis G70 AWD and it doesn’t dart of the line like this Sonata. You just BARELY touch that pedal, like just the weight of your foot, and BAM that thing takes off. I attempted to do a throttle body relearn by following a process I used on my Ford. Disconnecting both posts and connecting them to drain ECU capacitors. Noteable change in shift quality afterwards so confirms that shift points had been reset, smoothed out as it relearned values. No change to throttle though.
Any ideas? Vacuum leaks checked for and nothing. Filter is dirty but not awful. Runs like a top otherwise. 153,000miles.
