2012 Jeep Liberty 3.7L Powertec
It's been a minute since I posted on this forum. I'm more of a stalker. Since my last post, my Jeep has acquired 23K miles all on Valvoline Restore and Protect. On the next oil change I'm switching to Valvoline Extended Protection Maxlife High Mileage 5w30. Over the past 14 months, I've been inputting volumes of data from my fuel logs, maintenance logs, tons of questions about oil and filters; some of which were inspired by information I found on these threads, and some OBD-II live data into two AI's ,Gemini and Chat GPT. I couldn't think of a better way to make use of that data. Apparently, my 3.7 Liter PowerTec is a finely tuned machine in the prime of its existence. From Geminie, when I inquired about switching oils after 25K miles it told me,
The "Nitty Gritty" Take: You used the Valvoline Restore and Protect to "reset" the engine's cleanliness. Now, by switching to 5W-30 Extended Protection, you are providing the maximum possible physical protection for the metal surfaces and the best chemical support for the aging seals. This is the "Gold Standard" way to push a 3.7L Jeep toward the 250,000-mile mark.
And here's what I got from ChatGPT using one of the OBD-II files I imported.
SystemResultInterpretation
Fuel trims~-4% combinedSlight rich bias (normal, controlled)
STFT behaviorTight, stableBalanced injectors, clean combustion
O2 sensorsFull-range, fast switchingSensors healthy, responsive
MAP @ 65 mph~64–65 kPaSlightly better-than-average breathing
Volumetric Efficiency~82%High for this engine
Cruise power~52 hp (crank)Matches expected road load
Catalyst temps~740–755°FIdeal operating range
Bank balance~13°F deltaExcellent symmetry
Downstream O2Stable (~0.63V)Strong catalyst oxygen storage
Bottom Line​
Your 3.7L PowerTech is: Mechanically healthy, well-balanced, and operating with above-average efficiency for its design.
I'm no mechanic and without the help of the computer and AI I couldn't make sense of the numbers. If it helps me keep the paid-for vehicle running, then hell, let AI take over the world. 😁
So you letting that decide your oil use?
I'm not letting it decide my oil use, but I am allowing it to present technical information to me in a manner that is easier to digest and thus make an educated decision.
That’s pretty wild to get that feedback on a data upload. Yeah!
I like the 3.7. It’s an interesting motor. Split peen crank if I recall. A true truck motor with 2 less cylinders. Mine made some weird very light knocking noises if towing hot and heavy but it was as well balanced as a sewing machine and could spin all day long. The transmission behind it was one of the best I’ve ever owned. Daimler made good engines back then.
