hey guys
i drive a 2012 honda accord with a 4cyl K series engine. honda calls for 0/20. the car has 117k on the clock, im seeing some oil burn, in between changes. i change the oil every 5-6500 miles. i live in CA so i dont see any colder temps than 20F. what do you guys think of switching oil weight from 0/20 to either a 0/20 or straight 5-30. i currently use lots of different oils, ive tried PP, castrol edge, RP, havoline pro DS, and currently valvoline syn power. out of all these oils, i like valvoline syn power the most, seems to run the smoothest. the car is also a 5sp manual, i run use Redline MTL in the trans, which is a 75/80wt, same as honda man trans fluid. it shifts like butter with the redline.
