2011 BMW 135i Factory Fill 1300 miles
JHZR2
Staff member
New Jersey
This is the factory fill for my BMW 135i. I have also pasted the VOA of BMW 5w30 high performance synthetic for reference, though it is not necessarily the FF (though other than the Ca, Id almost say they were identical). Note the fuel dilution and viscosity loss at such a short interval. It should be doubly noted that at least 1000 miles of this was sustained driving at temperature, with the oil at temperature, which was 250-260F. The car has returned between 26-33MPG during this time.
The TBN was retained fairly well and the wear did not really suffer, IMO, considering the wear rates for the factory fill at 1300 miles compared to what I have seen and posted as used oil analysis for breakin oil change results from other vehicles. I have not touched the AF, and I assume the Si is due to gasket materials. I can't say this is very bad, and I will be interested at a longer OCI result when I take one at somewhere around 5000-7500mi.
Oil changing on the car is super easy, though I do miss the dipstick because it would make it easy to use an oil extractor to take a used oil analysis sample in the interrim to track wear rates, etc.
Code:
Sample Date 8/8/10 8/8/10
Unit Age 0 1300
Comp Age 0 1300
Time on Oil 0 1300
Time on Fltr 0 1300
Oil Maint. NA Changed
Fltr Maint. NA Changed
Fluid BMW Syn 5w30 OEM FF
Fe 0 20
Cr 0 0
Ni 0 0
Ti 0 0
Ag 0 0
Al 1 11
Pb 0 0
Cu 0 10
Sn 0 2
Si 5 10
Na 7 3
K 0 3
B 53 43
Ba 0 0
Mo 145 140
Mg 12 20
Ca 2051 2972
P 797 742
Zn 831 808
S N/A N/A
Cd 1 0
Mn 0 4
V 0 0
Sb 0 0
Oxid(PA) 7 11
Nitr(PA) 13
TBN 7.76 7.47
Kv@100°C 12.1 9.2
Fuel NONE 1.90%
Water
Hi: In regard to your comment on the dipstick, did they totally remove it, and if so, how do you check the oil level ?? Thanks.
And it is super easy to get a reading but the car has to have been running for a bit to get it.
The upside to this is that I would have to bet that the system would warn you when you get to a quart low.
I hope to never use that function... to find out if it does exist.
The downside is if/when the system gives you a false alarm. After the warranty runs out of course.
I say that, because my yellow oil light lit up when I got back. But the dipstick shows that it's where it should be. (Halfway between min and max says the manual.)
As long as it never glows red.....
Originally Posted By: dparm
Dear God, no dipstick? Leave it to the Germans to over-complicate something EASY.
Some Audi engines have no dipsticks either nowadays. You lucked out with your S4. :)
Amazing. Gotta love it, it just gets you into the stealership more often.
Sure wasn't any reason to dump that FF oil. Hope you broke that puppy in hard.
Complicate things?!? Sure it is an electric sensor, but no big deal... Do we fuss because we don't have a dipstick or sightglass for our gasoline level? By the way, that is an electronic gauge too...
Blue ridge parkway and skyline drive... Per the manual in terms of throttle and speed. The viscosity was getting scary...
Keeps "dipstick" owners from overfilling, underfilling, checking the oil level incorrectly, or not checking it at all.
Yes and the filter - none.
I did this more because all the M cars still get a 1200 mile engine, trans and diff fluid change (Ill do the others as I have time), and I wanted to get a grasp of fuel dilution in light of the excellent fuel economy I had been getting...
Is this suppose to eliminate Mr. 60k mile oil change? I'm pretty sure that moron would just ignore the light.
