So, I was looking in the owner's manual of my mom's 2010 Altima 3.5SR V6 and discovered the following information below the capacities and recommended fuel/lubricants chart (which can be found on page 9-2):
"*2: NISSAN recommends for the VQ35DE engine, Genuine NISSAN Ester Engine Oil available at your NISSAN dealer."
I did a google search and found lots of information about the need to use the ester oil on the Maxima and G37 vehicles, but I was unable to find any information about needing to use it in the Altima.
Puzzled, I went to the NissanUSA website and downloaded the manual for a 2009 Altima. In the 2009 owner's manual, there is absolutely no recommendation of using "Genuine NISSAN Ester Engine oil" in the VQ35DE engine. Clearly, the recommendation for Ester oil is something new for the 2010 model year.
In a way, this makes sense. Nissan has been recommending Ester Oil for the 2009+ Maxima's VQ35DE, which is essentially an enhanced version of the VQ35DE in the Altima. I'm sure the new recommendation for Ester oil in the Altima is merely a change that was done to ensure uniformity in oil recommendations across the board for all VQ35DE engines. However, there have been a number of reports on the G37 board of the Ester oil being very effective at curing start-up noise.
With that said, Ester oil is merely recommended, not required. In other sections of the owner's manual, such as on page 9-5, it only describes the importance of using an energy conserving oil that carries the starburst symbol and an API SM or later rating. Of course, just because it isn't mandatory does not mean it does not provide significant benefits-- as obviously, a number of people on the G37 forum have found that Ester oil cures some knocking noises.
Anyway, I have sent off an e-mail to Amsoil to ask what they recommend for this application. Exxonmobil has their response posted here and they recommend using their Mobil 1 5w30 and Mobil 1 Extended Performance 5w30 products. Redline's 5w30 contains large amounts of POE, but is on the expensive side.
Clearly, Nissan is slowly moving all of their VQ35DE applications to the Ester oil. I am assuming that if Nissan recommends it, the engine already comes factory filled with it, right?
So, what oil do you guys think I should use?
Thanks!
Thanks!
