Has 47k miles with 5k OCI using Pennzoil Conventional 5w20. Was almost 1 qt low (just above low level mark on dip stick) at last two changes. Have read several reports of the 10 MDX's using oil but mine never has until recently. I was always concerned about the fact I did not leave FF in until MM told me to change. Instead I dropped the FF at 5k. Wonder if replacing break-in oil too soon caused premature wear? Anything I should check or be concerned about? Thanks.
