Morning-
I'm having a weird issue with my 2010 Impala. Now that it has been cold the roads are pretty slick in MN. When I go to pull away from a stop sign and the tire(s) spin the traction control kicks on. With this I am getting a loud grinding noise from what sounds like the transmission and the car struggles to move with the traction control light blinking. It seems to be worse when I am turning from a stop sign and one wheel slips. I have to let off the throttle so the TC light goes off then it will pull away.
On dry pavement it never does this, pulls away just fine, trans shifts nice and strong.
I know the fluid levels are good, I dropped the pan and replaced the fluid and filter about 10K ago. It did this before that too so it's not the fluid.
I've felt ABS before and thought that maybe Chevy's traction control system was trying to help get me going by limiting wheel slip but this feels/sounds different.
Any insight would be awesome. It is under warranty but I always like to know if what I am hearing is actually a issue before I bring it in.
