- Joined
- Sep 26, 2010
- Messages
- 9,835
Gang,
[I posted this on the Kawieriders forum as well, but thought I would see if anyone had thoughts/experiences here]
I just managed to put the obligatory 10 hours (45 miles) on my Brute and so I am in the midst of changing all of the fluids. I plan to send the engine oil to Blackstone for a used oil analysis--I am worried about fuel dilution and shearing. This will also set a baseline and I will likely do every 3rd OC just to keep up with any changes.
This is a 2010 that was not sold until February of 2011 so I do not have any clues as to how long the factory oil has been in the engine. During the 10 hour break-in I did not over-rev the engine or go past the half throttle mark--however, it was not babied; it saw mixed throttle action throughout the 10 hour period.
The engine oil has a heavy gasoline smell and is quite thin. I have noted a heavy gasoline smell when I first start it and after warm up it goes away. However, on my last outing (which was a 3-4 ride) I began to smell gas while riding.
Is this normal for the Brute Force? Do I have a fuel system problem? Do you guys also have a gas smell to the oil when you change it? I am going back with a Kawasaki oil filter and Kawasaki 10w-40 oil for this oil change, but I plan to change to Rotella (T or T6) and a Purolator PL14610 filter on the next OC (anyone else running this combination?).
Please give me your thoughts about any or all of this. Thanks in advance.
