Hi All,
The front brake pads on my 2009 Vibe just passed state inspection by 1/32." I got it used with 29,000 and it now has 62,000 miles. The shop wrote me a $480.00 estimate for replacing the front pads and rotors. (I get a yearly inspection and rotation there, because they sold me the tires. They always balk at the balance part of "lifetime rotation and balance," but this time the receipt actually lists balance and 8 weights. The same old weights with three years of brake dust and dirt are on the wheels, though.)
Can I just replace the pads and clean up the rotors with a wire brush on my cordless drill? I haven't pulled the wheels to check the rotors yet myself, but from what I can see, there's a slight ridge around the outside and they are worn evenly otherwise. The brakes work as they always have, with no noise or pulsation.
My plan at this point is to replace the pads with Akebono ProAct ceramics. (The stock pads are apparently ceramic.) I'll also get a hardware kit and bleed the brakes.
If I end up needing rotors, I'm considering the AC Delco OE line at $63 each or Beck Arnley Premium at $50. The OE Toyota rotor is somewhere in that range, too. Would that money get me anything better than the AC Delco Durastop or Raybestos Professional at $30-$35? These are Rockauto prices, except for Toyota.
Thanks for your input.
