Originally Posted By: JohnBrowning
..Those ears where their to protect the head of the drain plug from damage if you actually went 4 wheeling into to some nasty stuff.
John, that sure is possible, but the little 'teet' I knocked off towards the front is super thin and literally took nothing to remove. Strangly enough, the tab towards the rear is much more substantial and kind off gusetted in to the casting more. I couldn't even get a thin wall, shorty, offset O2 sensor socket in there. Nor could I grind a 22mm socket short enough (to still have hex left) and still fit a U-joint, extension and ratchet handle on it.
Joel
