Went under the 08 grand Prix 3800 V6 in my signature to give it the first oil change since purchase. Some questions.
Was expecting to see a black shiny oil pan with a drain bolt. Instead it was grey, rough like corroded aluminum. Normal?
Could not get a socket driver on the drain bolt, too close to the transmission pan. I need to get a 13mm crescent wrench?
No visible drain bolt for the transmission pan. Do I have to flush it?
No visible coolant drain. Is it behind the shield?
