2007 Vibe coolant smell
Minnesota
I have a 2007 Pontiac Vibe, 1.8 L, auto. 110K miles. Been using the car to teach wife parrallel parking. When it heats up, I can smell coolant. It's a very faint whiff of it and I am not losing much if any coolant. Like over a year, maybe an ounce. I cannot detect the smell inside the cabin but standing outside, I can however, if I lift the hood, the smell quick dissipates.
Could the reservoir leak vapor and cause this? Would a new radiator cap help? Any ideas? No leaks on the ground and minimal loss of coolant over a year.....
radiator caps do go bad, and they're not a lot of money, but if you do replace it, get an OE cap
Does the car overheat?
If it has a coolant recovery tank, that's probably the smell. My new 17' Jeep Wrangler was doing the same thing. I learned to ignore it.
no overheating
My 2006 vibe has it every now and then. Look at the radiator. If I look down from the engine bay, mine has some crusted engine coolant on the fins. It's "leaking" I suppose but I very seldom top it up and it's not dripping so I just monitor every oci.
