The TAN is nice and low, so you could run a lot longer in theory from that standpoint. Without a particle count, you don't know much else. You really can't tell too much from these numbers because they are all 10um.
If it were me, I'd take another sample and stow it away, install an inline trans filter and run 10-15K, then take another sample and do just TAN and a particle count on it. Bear in mind Blackstone can only do the pore blockage method (google it), so it's more "contamination analysis" than an actual particle count. It's fine (and low cost) for something like this that needs a ruler and not a microscope but not directly comparable to an optical count (which is more expensive). If you want to compare the before-fitler/after-filter contamination analysis, you can send the earlier sample in for just that test. All that will probably cost as much as changing the oil and filter, but you'll know.
