My 2007 Escape isn't cooling adequately in hot weather and both my shop and the dealer can't seem to figure out why. They say it cools fine in their shops with a 40F temp drop across the coil. The issue is when it is hot outside, the temp drop is only about 20-25F. The refrigerant levels are good. There are no leaks. Compressor is OEM and replaced 2 years ago.
The dealer thought it might be the heat blending door since it wouldn't fully close but I got that wedged fully shut but no change in output temperatures.
When I'm testing I use the following:
- Fresh air intake
- Fan setting 3 of 4
- 7" temp probe inserted in middle dash vent and adjusted to make sure it isn't touching the sides of the vent ducting
- Escape has been sitting in garage for at least 2 hours
- test in the evening when no direct sun is present
I tested another escape at the dealer and it was hitting 40-45F using my testing methods, easy, even in full sun.
any guesses on what else it could be?
- Fresh air intake
