Stop being petty and whiney and move on then.quote:
Originally posted by ekpolk:
Now, can we move on with this intriguing topic . . . please?
Please check the blackness of your own whining pot before you go to town on my kettle. And stop sticking fingers in other members' eyes if you don't want it done to you. I tell you what -- after you've finished your 26th year of service as a Marine, and made it to the rank of O-6, then you can come tell me what's becoming a Marine and what's not.quote:
Ray:quote:
Originally posted by Ray H:
Dave H, I don't disagree with you in the least. (very thoroughly researched and well-written argument, by the way -) But, don't be surprised if Nissan caves, too. It's sad when like-minded ("Don't confuse us with the facts, our minds are already made up.") gub'ment functionaries presume to pressure engineers to their politically correct mindset. Sadder yet when otherwise knowledgeable car owners swallow the swill, run around waving their arms, and shout, "Hallelujah - herald the dawn of the 5W-20 millennium! Surely, goodness and grace shall follow forevermore."![]()
I didn't make any statement about thin vs thick or what is better. I just stated the fact that the recommendation is different in Europe (and almost all other places than NA). The consensus in Europe is to use a thicker (> 30wt) oil when it is necessary (towing or sustained high speed driving).quote:
Originally posted by G-Man II:
IMO, the fact that some auto makers spec different grades of oil in different parts of the world doesn't prove anything in the "thin vs thick" debate.
I'm a vet, where's my avatar...quote:
427:
If you're a vet too, then you of all people should be able to handle the heat when you enter the hot kitchen with such barbed questions as, "What's your point?" If you want the dish, then expect to have some dished back. Also as a veteran, you should realize that Marines, of all people, aren't afraid to get into a firefight, anywhere, anytime; fer cryin' out loud, this is easy here. Now, can we move on with this intriguing topic . . . please?
Did you ask Tony for one?quote:
Originally posted by Nickdfresh:
I'm a vet, where's my avatar...![]()
Maybe when I have a few more posts thrown in...quote:
All you have to do is ask. That's the only way he will know you are a vet and want a vet avatar.quote:
One little correction Dave. 5W20 is not necessarily thicker then 0W20.quote:
As for the original post, I personally would use the heaviest oil recommended. In the case of the '07 Toyota Camry, would that be the 5w20?
Yes, I offered an "olive branch" to stay on topic and discuss the technical subject at hand. But ekpolk just had to throw that "jab" in about me listing Mazda. And when I explained why I listed Mazda, he refused to move on. I call that petty and whiney. I've worked closely with Marines for many years, and it's not the type of behavior I remember.quote:
Originally posted by Dave H:
427,
You had asked ekpolk to post the bearing clearances and oil pump specs for the VQ35.
Dave, we've heard that arguement dozens, if not hundreds of times already. And if you step back and think about for a moment it's really a lot of inferences made on a lot of weak assumptions. It's all been hashed out ad infinitum, and I don't care to repeat it again.quote:
But I do know the different recommendations for my engine in the US and Europe. As I posted above, the recommendations in the US are lower than in Europe. This strikes me as odd, so I brush off the common sense and get to figuring (which means I could be wrong, so if I am someone please enlighten me).
427:quote:
427,
I stated the above bearing clearances aren't the reasons VQ engines aren't apparently "thin oil" friendly. But there could be many other reasons why they're not. A look at bearing design equations will give several more parameters we haven't even considered. And that is just the main and con bearings. There are many other parts of the engine that could influence it's preference for one grade over another. I haven't been through all the UOAs on these engines in the analysis section to see if there's a significant difference, i.e., differences above some noise level, but if there is, so be it and I'm sold.
You proved nothing. Ask anyone who replaced the 5w20 in their MDS equipped Chrysler product with thicker oil. Further, you assume all engines/accessories are identical or have the same operating parameters just because they come from the same engine family. This is a false assumption.quote:
Originally posted by 1sttruck:
It proves that thin oils aren't required 'for proper operation', as is often stated, since the maker is recommending thicker oils outside of the US.
Again, you proved nothing. There is more to it than just clearances/tolerances. As a first step, review the bearing design equations and all the parameters involved.quote:
It proves that thin oils aren't required 'because of clearances', as is often stated, since the same engines in many cases are being used outside of the US.
Honda doesn't state that using a "thicker oil" provides any advantage. That's an assumption on your part.quote:
Where a range of oils is recommended outside of the US, such as in the case of Honda, they state that thinner oils are recommended for fuel economy. With other makes it's not uncommon to see that thicker oils are recommended for sustained high speeds.
See above.quote:
It supports the case that thinner oils don't appear to do as well in outside of the US, where drains are extended compared to the US, and where sustained speeds can be higher than in the US...
Engines can be designed to run a wide variety of viscosities. Manufacturers consider other parameters besides viscosity when designing an engine such as current formulation technologies, cost and availability of current formulations, and user habits and beliefs. Ford only specs thicker oils in extremely low volume production specialty vehicles that are essentially aftermarket built engines that have taken the original design way past it's original design and development parameters. In short, the thick oil is a patch for a few thousand vehicles that won't see the usual validation/verification process.quote:
...and where more higher performance vehicles appear to be offered than in the US. Even Ford has recommended 15W50 and 5w50 in it's very high performance vehicles in the US, which isn't surprising as other makes of similar types of vehicles appear to recommend some pretty thick stuff too.
Done.quote:
Shall we bury the hatchet?![]()
IMO, the fact that some auto makers spec different grades of oil in different parts of the world doesn't prove anything in the "thin vs thick" debate.quote:
Originally posted by bar1:
I've tried to tell 427 (and others) about differences in recommended visc. in Europa for Ford and Honda engines.
The 'thin is better' crowd will not listen![]()
Since the thread's not dead yet, might as well have some fun with this one...quote:
Originally posted by MC5W20:
Umm, I agree. What is your point. Ford owns 33% of Mazda. So what is your proof that Ford calls the shots when they are in minority control of Mazda. If your going to make unfounded claims be prepared to be called out on your bull****. I guess the possibility of 5w20 oil being superior to the others never crossed your mind.
