Hello folks,
I am planning coolant flush of my 2006 Sentra system, for the first time in its life, 11 years/103,000 miles. I have few questions in that regard.
I plan to follow the procedure listed in this video. In this video, he uses, radiator flush and cleaner along with distilled water to flush the system. Once flushed he uses Peak 50/50 premixed coolant and Peak anti-rust & sealer additive.
My questions are,
1. Does this method sound reasonably good to flush the coolant?
2. When you flush the system with water, do you get ALL water out of the system? Because if it does not remove all water then using 50/50 pre-diluted coolant is not a good idea.
3. On this board, I noticed that many people recommend ZEREX™ Asian Vehicle Antifreeze/Coolant (blue/red?) for Toyotas, Hondas and Nissans. Is there any specific reason why this is recommended, because I checked Peak and Zyrex coolant SDS and looked very similar, made of ehtylene glycol, diethylene glycol and benzoate. So I am curious what advantage Zyrex offers over Peak.
Thanks in advance
My questions are,
Thanks in advance
