I posted a while back about my 3800 starting issue. Since then, I replaced the plugs and wires, cleaned the MAF sensor and replaced the air filter. I think it's getting progressively worse. Often, when I restart the engine after it has been sitting for a while (never completely cold or warm), it takes 2-4, but usually 3 tries to start it. It starts then seems to starve off and die. When it's running it runs fine. The car has 140k miles and is in good shape, so I want to figure this out, and any help would be very appreciated!! I took a couple videos so you could see the problem. Links are below:
Two different days:
Video #1- Buick starting problem
Video #2- Buick starting problem
What I've done:
-New ACDelco Iridium plugs & ACDelco wires
-New air filter
-Cleaned MAF sensor
-Ran Techron through the gas
-Pulled negative battery cable for 20 minutes to let it relearn idle (per GM instructions)
-Took it out for a longer highway trip to burn through the Techron
-the car DOES NOT HAVE an IAC valve. I know that's a logical solution but it doesn't have one.
-If it matters, the car is drive-by-wire so it's mostly computerized.
Thank you so much everybody! This forum is great!
Two different days:
What I've done:
-New air filter
-Cleaned MAF sensor
