2006 Jeep Liberty Differential
MN
I have a 2006 Jeep Liberty and am suprised to see that the manual calls for front and rear differentials to have the gear lube replaced at 15,000 miles. This seems a bit extreme to me and wonder why such a short interval.
I don't trailer anything and only drive it about 6,000 miles per year. Comments/suggestions?
That is what Alldata lists under severe service. To change it out every 15k. How many miles are on the vehicle now?
Both diffs need to be changed at 15k indeed. I'm at 33K miles on my Liberty and both diffs were done at 15k and 30k. 75W-140 Synthetic in both diffs.
Follow what the owner's manual tells ya and you'll be fine. I also recommend changing the t-case fluid and having the auto transmission flushed every 30K. Both take ATF+4.
I presently have just over 21,000 miles on the odometer.
Regarding the transmission, Jeep tells me not to use a synthetic transmission fluid - only ATF+4, but only at a 50,000 mile interval.
Some of the intervals seem shorter than what you would normally expect, i.e., diffs. at 15,000, spark plugs every 30,000, coolant and transmission at 50,000.
I'll just follow the owners manual - gotta be smarter than I am!
I believe any ATF+4 is group III, So that is synthetic. Spark plugs are copper, so yes 30k max. Alldata says to check transfer case and add as necessary at 30k. As for the trans and transfer case, the recommended service is 60k.
If the diff magnets are in the drain plugs as with my Suzuki 4x4 then they may get pretty loaded up with break-in particles by 15k and need cleaning to be effective.
My '06 owner's manual calls for diff fluid changes at 15k under the severe (B) service schedule. However, it also includes the following footnote:
‡Off-highway operation, trailer towing, taxi, limousine,
bus, snow plowing, or other types of commercial service
or prolonged operation with heavy loading, especially in
hot weather, require front and rear axle service indicated
with a ‡ in Schedule “B”. Perform these services if the
vehicle is usually operated under these conditions.
I doubt that most vehicles are "usually operated under these conditions". I use a good syn fluid, and change it every 30-50k. JMHO.
