Originally Posted By: Ramblejam
Originally Posted By: 95busa
Thanks for the response. I am sure it will be fine. I am pulling with a 330ci naturally aspirated engine in a heavier vehicle (6000lbs, not six tons), with a roughly equivalent gear ratio (3.73-1 with 33" tires as opposed to 3.42-1 with roughly 30" tires), shouldnt be an issue.
I was thinking about a ~12k GCW (7k truck + 5k trailer). My mistake for not clarifying.
The comparison you're making is misleading and flawed, as it's truly apples-to-oranges here; with a significant load in tow, the driving experience between a Super Duty/TorqShift and Yukon(1500)/4L60-E will be vastly different.
Man---I could go on for days on this one. I have pulled this with a v6 F150. I have also pulled it with my F250. News flash- pulling POWER wise- not much difference. The torqshift has a lower first gear, 1-1 (most common gear I use when towing) is THE SAME. The biggest difference is suspension, which I grant you is night and day. Some Bilsteins in the back or helper springs and I think it would be ok. We will see. Clearly durability wise- the F250 could do this every day for 200K miles. A half ton- not so much. Once again- I am unsure what this has to do with my question- which was durability of the truck. Not your opinion of how subjectively well it will tow. This is what I hate about BITOG
