2005 Suburban 1500 Rear Differential
California, USA
The rear diff on my 2005 Suburban 1500 is in need of a fluid change. It has the RPO code G80, but is it a mechanical locker or LS? I need to know if it requires any friction modifier, and I don't want to put in some LS additve if it is an Eaton.
Originally Posted By: clinebarger
You have a Eaton Gov-Loc, No LS additive needed, Though I run Mobil 1 75w-90 LS in my 11.5" Gov-Loc with no issues.
Ive wondered about this, since most have the LS additive.
Originally Posted By: RedOakRanch
Go to auto zone and get the demo synthetic for 5.99. It's been cheaper than Dino for 2 years.
Good tip. But when I was looking it up it said that it's non-automotive. Does that matter?
You'll find a lot of discussion about this buried back in the forum if you search it right.
If I remember correctly, and I might be wrong, the locker doesn't require EXTRA friction modifier like a limited-slip would. I don't think that means it requires a fluid with NO FM, because the unit does have a type of clutch plates. They just don't do the same thing as the clutches in a limited-slip rear.
Amsoil Severe Gear, which includes some FM, is working fine in my 2001.
Originally Posted By: cdm1993
Appreciate the help. Interesting. You don't get any chatter?
Nope, No difference from the Factory Fill or the Royal Purple Max Gear I had in it before the Mobil 1.
