2005-08 Forester/ 2005-07 Impreza Recall
Huntington Beach, CA
Service Program WVL-22 (2005 - 2008 Forester or 2005 - 2007 Impreza with 2.5L non-turbo engine)
Dear Subaru Owner:
We would like to thank you for selecting a 2005 - 2008 Subaru Forester or 2005 - 2007 Impreza with a 2.5 Liter engine (non-Turbo). At Subaru, we take pride in our products and are committed to your continued satisfaction.
During a quality review, we discovered that the one-way fuel valve located in your vehicles fuel tank may not perform as intended and could cause a condition that may damage the catalytic converter. To prevent this condition, the one-way fuel valve must be permanently removed from the fuel tank. Removal of the valve will not adversely affect the performance of your vehicle because it has been determined this valve is unnecessary.
ADDITIONAL INFORMATION
The one-way fuel valve is located at the base of a small sub-chamber contained in the fuel tank. When the tanks fuel level drops below 1½ gallons, the sub-chamber is intended to provide a fuel reserve for the fuel pump during vehicle cornering. However, the one-way valve may inadvertently act in such a way as to prevent fuel from refilling the sub-chamber, failing to provide the intended reserve. If this were to happen, the fuel pump could momentarily draw air, causing the engine to experience a sporadic misfire condition resulting in possible damage to your vehicles catalytic converter. (The Check Engine light will illuminate to alert you if the catalytic converter efficiency has degraded beyond an acceptable level and if your vehicle may be releasing air pollutants that exceed emission standards.)
WHAT WE ARE ASKING YOU TO DO PROMPTLY
You should immediately contact your Subaru dealer for an appointment to have your vehicles fuel tank one-way valve permanently removed. The approximate time to perform this repair is 30 minutes. However, it may be necessary for you to leave your vehicle for a longer period on the day of your scheduled appointment to allow your dealer flexibility in scheduling other appointments. Your Subaru dealer will perform this repair at no cost to you. Since it will be necessary for your dealer to remove the fuel pump from your vehicles fuel tank to access the one-way fuel valve, it would be helpful if the tank were less than half full at the time of service.
CALIFORNIA REGISTERED OWNERS
The California Air Resources Board requires that emission related campaigns be completed prior to Californias vehicle registration renewal process; without this repair, you will not be able to register your vehicle during your next annual registration. Upon completion of the services required by this campaign, your California dealer will complete and provide you a Proof of Correction Certificate.If required, present the certificate to the California Department of Motor Vehicles when renewing your California registration as proof of campaign completion. If the DMV does not request the certificate, we recommend that you keep it for your records.
In addition, the State of California requires that every vehicle must pass an emission test (SMOG Check) every two years and before it is sold. Without the free service we are providing, your vehicle may be more likely to fail this test and require that you make costly repairs.
IF YOU NEED FURTHER ASSISTANCE
To locate the nearest Subaru dealer you can click here. You may also email us by clicking here or call us at 1-800-SUBARU3 (1-800-782-2783) during normal business hours for assistance. Please call us immediately if the dealer fails or is unable to complete this procedure free of charge. Your continued satisfaction with Subaru is important to us. This modification is intended to assure your vehicles optimal performance. We sincerely apologize for any inconvenience this matter may cause and urge you to schedule an appointment as soon as possible to have this repair performed.
Note: You may be receiving this prior to a postal notification of this information. This is either because we have your email address on file or because you have registered to receive alerts through MySubaru.com. Please feel free to schedule an appointment with your Subaru dealer to have this repair performed even if you have not yet received your notification by mail.
Sincerely,
Subaru of America, Inc.
california ......
I just got one on my 09 forester PZEV to reflash the ECU due to catalytic converter damage issues at WOT and heavy throttle/ high speed operation. Are they going to but an electric brick under my gas pedal?
