2004 Camry Rear defrost disconnected...
The Rockies
Rear defrost is not working. Apparently this is disconnected. But the tab that it's supposed to connect to isn't obviously visible. Before tearing into things I just wanted to check to see if anyone knows where the tab would be. Thanks!
The terminals are mostly obscured by the C Pillar trim
It pops off fairly easily
See here @ 2:55 or so
Right, look under the trim.
IIRC, that trim has to come out to access under the package tray to do things like replace rear shocks, etc. May have been overlooked if any work like that was done.
