Helped a freind change compressor on 04 camry with manual ac controls . swapped compressor and did a vaccum and charge by weight . works great with 40 degree temp from the vents .
Every once in while the A/C light will blink and A/C will shut down . a quick on /off press and it restarts . According to the net, this means there is an issue in the A/C system . locked compressor . low charge most common . none of these seem to apply .
The one thing i i do recall is it had this issue before we swapped the compressor . i have changed the relay . its so inttermitent that can't reproduce it at will. No codes . A/C when it works , which is 99% of the time , is ice cold.
I think its an electrical or ecm issue . not sure how to test the ecm . Any suggestions on what else to do?
