Hi all,
I have a 2003 toyota echo with 115,000 miles on it. It has a slight gear whine between 35 and 50 mph which as I understood is a common problem with Aisin-Warner transmissions. The whine does not get any worse and was present since I bought the car in 2008. I replaced the original ATF fluid with fresh T-IV at 94,000mi and then at 110,000 miles again. The whine is still there. I recently did used oil analysis on this ATF and found that the viscousity was low (6 at 100C). I wanted to post the used oil analysis report here for everybody to look at but could not figure out how to attach a PDF file. The iron wear metal was low so I am assuming the transmission is still healthy. I don't have any other issues with it except this whine. Some people have reported that switching from T-IV atf to Redline D4 makes the whine go away. Does anybody have any experience with Redline D4 in toyota transmissions? I want to try it in this echo (doing a full flush) and see if the whine will go away, but wanted to check here first as Redline is kind of expensive.
Thank you!
Thank you!
