Doing brakes on my truck and found axle seal seeping on right side. Parking brake was oily. YouTube video of axle removal didn't look toooo bad. Would have to drain and fill rear diff.
I'm thoroughly confused as to what gear lube should be used for rear differential of a 2003 GMC Sierra 1500 4 WD with Z71. It's got a locking rear differential, not limited slip. Pretty sure it's the G80. Some things I read say use no LS additives. What if the oil already has some additive in it? Is Mobil 1 or Valvoline Synpower 75w90 OK or do I have to go to dealer for the GM product? What oil have you had success with?
