I had picked up this car (02 Sebring sedan 155k) last year for cheap ($1400)because it needed front end work.
I finally decided to get the work done a few weeks ago .So I hit RockAuto. I wanted components that were greasable so that disqualified the low end products. I ended up ordering the Mevotech premium complete front end kit and 4 Monroe shock/struts .About $750. The items were quickly delivered however one of the struts was in a box labeled "original box damaged beyond use" . ok.
Loaded it all into the car along with some oil and dropped it off at a shop that I had good recomendations about. Later I realized that I neglected to put the oil filter in the car so I drove over to drop off the filter. When I got there The mechanic told me there was a problem and walked over to the car and moved the front driver side strut that gave off a squishing sound-blown. It was the strut from the damaged box. ****. I ordered a replacement strut, I'll have to contact RockAuto about returning the strut and getting a credit. The mechanic also pointed out a leaking cv axle and I okayed that replacement. A few days later the strut was delivered and installed and they had the front end aligned and called me to pick it up.
So for a complete front end replacement , shock/struts,cv axle , front end alignment and an oil change for $1045. The car has an extra 2 inches of clearance in the wheel wells , handles well,hugs curves and soaks up bumps.
I'm real happy.
I'm real happy.
