Originally Posted by CBR.worm
I don't know for sure, but I would imagine your car uses some variety of the Jatco RE5R05A, that transmission is/was used in most RWD Nissan and Infiniti cars and trucks with 5 forward gears and RWD/AWD. It is supposed to be a fairly reliable unit capable of holding a decent amount of torque - except in the Titan and Armada, which I understand had cooling issues. I also understand that transmission techs that don't have experience with its quirks tend to have a hard time. There are many things that can cause it to behave differently when hot vs cold, both electrical and mechanical. A shop with experience with these can watch the realtime data and get a pretty good idea of what is going on. These are adaptive transmissions that monitor ATF and engine coolant temperature as well as line pressure at multiple points and RPM of turbines and many gears, throttle position, brake light state, even A/C operation. There are many sensor readings that could be flaky enough to cause driveability issues without triggering the AT light or CEL In my limited experience, shifting hard is better than slipping and ruining the remaining friction surfaces.
You may need to take the car to a shop that specializes in 350Z/G35/G37 cars or possibly a shop that specializes in Nissan/Infiniti trucks. Someone who will have had lots of experience either building these to handle more power, or repairing them after someone cooked them at the track or in the mud. Maybe this guy is one of them?
250K isn't a bad life out of an auto transmission behind a high RPM 350hp V8 in a heavy car. I'm a couple of years from that mileage, and I'm already trying to get an idea of who will be able to work on it when it breaks.
Sure sounds like I need to find someone who knows these transmissions. Been on a few other forums and not getting anywhere with this issue.
