2002 Ford Crown Victoria 200k, 5.2 on Maxlife 5W20
Central Washington
Previous UOA
Finally! After a month I have the results back from my oil change on 4/25. I put in the sample information online, but when it got scanned in at their facility, it didnt come back to anything so it got shelved. I emailed back and forth a few times and got it sorted. Finally recieved the results this morning.
Oil was Maxlife Syn 5W20, but I added a quart of Synpower 20W50 about halfway through to quickly boost the viscosity into 30 grade, which appears to have worked.
Filter was a Fram XG2 I reused. At the end of the OCI it had about 18k miles on it.
Still using Lubeguard Biotech oil treatment at 3oz/qt
Code:
Iron 19
Chromium 0
Nickel 1
Aluminum 22
Copper 4
Lead 0
Tin 0
Silicon 13
Sodium 262
Potassium 1
Titanium 0
Molybdenum 212
Boron 8
Magnesium 9
Calcium 2130
Phosphorous 853
Zinc 771
Fuel
Soot
Water
Visc 10.3cSt@100C
TBN 2.86
Oxid 16
Nitr 11
Lab is OAI/Polaris
After peaking at 27ppm last OCI, the Al is finally trending back down. Very happy. I did look at the filter for signs of metallic contamination from the timing chains, but found none.
Impressive that you went 19K miles on that Fram XG2 filter. I use the same one on my 2002, though only for about 8K miles/yr total (2 OCI's).
It was in use for almost exactly a year. 05/03/16@182,000 miles to 4/25/17@200,000 miles
How many miles on this oil change and how many quarts of makeup oil? I don't see it in your post? 18k on the oil or filter?
Whoops! In my excitement of finally getting this report Im completely forgot.
The oil was in for 5,250 miles. Only the oil filter went 18,000.
Top up was 1 quart. The quart of Synpower 20W50 I added.
I use the same combination in my Accord, save the filter -- which is an Ultra. I want to get 7K out of the oil with Biotech.
The only things that concerns me is the Al. If it was trending down here (previously 27) then I'd say there's an issue somewhere.
I realize you've used Polaris, and most of my data comes from Blackstone, but the 5k miles in your UOA is pretty much the average duration for most. Typically we'd see about 4ppm of Al in 5k miles; you've had 27 and now 22. Good that it's coming down, but from what? Could be a particle streak? The Cu and Pb are not bad on yours. I've heard (but admit I have no ability to confirm) that Ford used aluminum bearings rather than traditional Cu/Pb in some applications. You may or may not have an issue here.
Continued monitoring is key.
Yes, this engine does use Al bearings. Not Cu/Pb. So it could very well be lower end wear.
Im going to keep up with UOAs and stick with my ~5k mile oil changes.
