Originally Posted By: MrRPM
right, i know what the problem is, i have a 2001 so i keep my eyes peeled and am always checking over things to make sure it hasn't happened. Next to that i hear about piston skirt failure (but have only seen 1 real case here it appears, haven't seen it anywhere else, just "heard" about it.) I have also seen tons of oil pump drive gears stripping out on 05/06 wranglers on the web. People are always talking about common problems that can cause failure of the engines. That to me says they aren't the reliable tractor engines they are made out to be. Im also thinking maybe i just spend alot of time online where people go to discuss the problems and I see it alot and feel like its over discussed lol
Like you said I think it has a lot to do with discussion forums. Often people will have a problem and seek out an online forum for help. According to jeepforum.com, about 1/3 of the 0331 heads crack, but that only includes the members of the site, and those who actually cared enough about the issue to participate in the poll. There are many more out there running flawlessly that go unnoticed.
Mine overheated so I replaced the head as a preventative measure even though it never cracked. My previous 2000 XJ didn't crack for the year I had it, my friend's 2000 XJ hasn't cracked yet, and my other friend's 2001 XJ hasn't cracked yet also. I'd just keep up with the maintenance and you will be golden. I've seen later 4.0s that were hydrolocked, then restarted, and some that were even run upside down.
