2001 Impala Burning Oil
Kansas City Metro
My girlfriend's Impala with the 3.8L engine is burning oil and I was wondering if I should worry about it. I know every engine will burn a little because the top of the engine need lubricated but her car burns more than a little in my mind. We recently took an 1,100 mile round trip journey to Denver and the car burned nearly a quart of oil. That seemed like a lot to me because my truck and my motorcycle would never burn that much. The engine sounds smooth with no odd noises, smells or smoke and power seems good. Everything seems healthy other than the oil level dropping. I am not anti-dino but I am a big fan of synthetics and I would like to run synthetic in the engine but if it is going to burn it all off, I can't see spending the money. Is there a chance that a switch to synthetic would reduce consumption? I can't see why it would reduce consumption that much but I am looking for anything.
Michigan
3.8 are rocks. I'd RX it to see if that might help. Was it bought used? For a synthetic, M1 HM would be a good choice.
Chicago, IL
the 3.8 is one of the most durable engines from GM. but... GM made a few changes back then that have greatly increased problems: plastic intake manifold, Dex-Cool (which eats away at the intake manifold and head gaskets) with that low mileage, I strongly suspect either a leading intake manifold gasket (very common) or a leaking head gasket (less common, but still problematic) obviously there are some tests that can pinpoint the problem. (compression test, etc) also look very closely at the intake manifold gasket - frequently you can actually see the oil leak.
Chicago, IL
are you losing any coolant? is your coolant resevoir full to the proper level and the coolant is pink/red? Or is the level low and brown?
dsmith41
Kansas City Metro
There is plenty of coolant and it looks good. In fact, I just changed the thermostat last fall because the temp gauge wasn't moving at all an the fan ran constantly. New thermostat fixed it.
northeast
Here is a bulletin on this for oil consumpution. #2034062 Some customers may comment of excessive oil consumption on the 3800 Series III engines. An engine that has excessive oil consumption uses 0.9L (1 qt) of oil or more within 3,200 km (2,000 mi). This condition may be caused by the retaining ring on the exhaust valve stem seal not securely holding the seal on the cylinder head guide boss. If this occurs, the exhaust valve stem seal(s) may move off the cylinder head guide boss and no longer provide a sealing function between the exhaust valve stem and the valve guide.this bulletin covers 06-08 lucerne with 3.8 vin code 2 and 4.
northeast
Subject:Information on Engine Oil Consumption Guidelines #01-06-01-011C - (12/13/2006) Models:All 1998-2007 GM Passenger Cars and Gasoline Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn)2003-2007 HUMMER H22006-2007 HUMMER H32005-2007 Saab 9-7X -------------------------------------------------------------------------------- This bulletin is being revised to add the 2007 model year. Please discard Corporate Bulletin Number 01-06-01-011B (Section 06 -- Engine/Propulsion System). -------------------------------------------------------------------------------- All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the power stroke, part of this oil layer is consumed in the combustion process. As a result, varying rates of oil consumption are accepted as normal in all engines . Oil Consumption The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi). Important: Certain 2006 and 2007 models have a new GM Extended Warranty. Please refer to the appropriate Owner's Manual for warranty information. This rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or 80,450 km (50,000 mi) for Cadillac, driven at legal speeds in an unloaded (for trucks) condition. Important: This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks). Oil consumption for vehicles driven under these conditions will be more. Many factors can affect a customer's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pan and engine covers for leakage due to over-tightened, damaged, or out of place gaskets. Inspect oil lines and fittings for signs of leakage. Improper Reading of the Oil Level Indicator (Dipstick) Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Important: Refer to Owner Manual in SI for checking and adding engine oil. Not Waiting Long Enough After Running Engine to Check Oil Level Some engines require more time than others for the oil to drain back into the crankcase. To assure a sufficient amount of oil has drained back to the crankcase, and an accurate reading can be obtained, the vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Important: This does not apply to 2006 and 2007 Corvette ZO6 equipped with the 7.0L LS7 engine (dry sump). Follow the instructions in the Owner's Manual for checking the oil in this application. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. Aggressive Driving, High Speed or High RPM Driving Aggressive driving and/or continuous driving at high speeds/high RPMs will increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer will increase oil consumption and may cause oil consumption to fall below the normal accepted rate referenced in this bulletin for an unloaded vehicle in a personal use application. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution (Fuel and Water) On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, unburned fuel and condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture and fuel, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi). Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that the oil has had time to drain back into the crankcase. Verify that the oil level is at, but not above, the full mark on the dipstick, and that the proper viscosity and quality oil are being used as recommended in the Owner's Manual. Record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Ask the customer to verify the oil level, each time the vehicle is fueled, following steps 1-6 and return the vehicle to the dealership if the oil level is found at or below the add mark, 0.946 liter (1 qt) low. If the oil level remains above the add mark, the customer should continue to operate the vehicle and verify the engine oil level until 3200 km (2000 mi) has accumulated before returning to the dealership for a final evaluation. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 3200 km (2000 mi), follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 3200 km (2000 mi), explain to the customer that their engine meets the guidelines for oil consumption.
Chicago Area
Nice homework by lucerne! But concerning the oil used... Was it down a qt. after the trip but not checked properly BEFORE the trip?
