I am planning, using Castrol EDGE 5w30, to increase my OCI from 7,500 miles to 10,000 miles. I thought this would be a no-brainer, but I have seen some folks suggest that the v6 Honda engines are not that easy on oil. Any advice, thoughts? Thanks.
Lots of highway miles? If so, it could probably do 10K EASY-but if there's a lot of stop & go, short trips, long time between OCIs-oil analysis would be the only way I would try to go that far.
Originally Posted By: TomYoung
Originally Posted By: beast3300
Some of the used oil analysis aren't supporting a long drain capability of Edge.
A check othe oil's condition may be a safer bet to run it to 10k.
Thanks -- would you support the 10,000 mile OCI on PU?
Even though PP, PU, RL, M1 and some other brands have done 10k oCI, a used oil analysis is still the safest way to determine if you engine likes that particular oil. My longest OCI was 4800 miles so I am not an expert on long drain.
