Originally Posted By: dnewton3
Changing out oil too soon is a waste. Why spend all that money on an expensive lube, and then pay $35 for a UOA, to then ignore the data and dump oil too soon?
Does one put down the beer and grab another one, just because he can see he's nearing the bottom with 2.8oz left in a 12oz can?
I'll make a wild guess estimate that the M1EP started with TBN of 9? So, you're only about 2/3 the way down the scale. Why would you throw away perfectly good product with life left in it?
Blackstone recommends TBN to be no lower than 1.0 on their scale. Being that your TBN is at 2.8, you have PLENTY of life left in that lube. 10k miles is doable; probably more.
Agree with the TBN. Busters link above has a reply from XOM. They state:
"As for TBN retention, it is only a single parameter that provides an indication of the used oil condition. A reduction in TBN is an indication that the overbased detergent is doing its job by neutralizing acids that form as a result of combustion. TBN should be used in combination with other used oil parameters such as oxidation, nitration, TAN (Total Acid Number), ICP metals, D4684 MRV viscosity, and D445 kinematic viscosity to determine the overall condition of the used oil."
So, its well within spec, and even if it were close, its not necessarily a danger.
My only issue was stated in prior post. I don't agree with extending the first synthetic OCI after years of dino, and gave the reason why. XOM thinks so too.
