Yes, this is the Taurus we just bought. Tonight when driving home on the interstate I looked down and saw a blinking light on the dash (gear symbol with exclamation point). I noticed at that point that the transmission would not go into overdrive. Other than that it drove fine all the way to our next stop.
Upon stopping and restarting the engine all is running as it should again. I know the next stop is to pull codes, but no one in our area let’s you borrow scan tools anymore so I may wait and see if it acts up again before taking it to a shop to have it scanned.
Also worth mentioning, I just changed the fluid and filter last week. I check the level when we got home and it was right at the top of the cross hatching on the dipstick.
Hard to say without codes I know, but any chance this was just a fluke? The light didn’t start blinking until freeway speeds (60+ mph) and it did happen after getting up to speed using the on ramp (no I was not flogging it, 3500 rpm max).
Not seeing a lot on the Taurus forums, those are mainly slipping complaints or all our failures.
Here are some acceleration clips AFTER restarting the engine. It’s acting normal here, both videos show torque converter lock up.
At the end of the videos you can see where I lift off the throttle and the tc unlocks then locks back as it should, I do this a few times so the rpm fluctuation is due to that. Also, please ignore the power steering whine lol.
