Hello everyone - this is my first post on the forum, thank you in advance for your collective knowledge and insight.
I have a 2000 Olds Minivan that is overheating. The shop has replaced the thermostat which seemed to be the cure initially. Now 4 weeks later, it's overheating again.
When I am in motion, the temp goes back down. In stop and go traffic, it heats up to the red.
My new mechanic thinks the water pump is going and the head gasket was probably burnt when it overheated 4 weeks ago.
If air passing through the radiator (while driving "fast") cools the engine, it means water is circulating, correct? Would that indicate the water pump is working right?
Any ideas what is causing it to overheat?
I did a quick search and am not sure what the answer was. I am happy to try to trouble shoot or answer any questions I did not cover in the post.
Again, many thanks for any help.
