2000 chevy 454 OBS K3500 Crew cab dually truck
Started out the thermostat needed replacing because it only got up to 110 degrees. Which caused us to change the original heater hoses dated 1999. Then decided to change the spark plugs (badly worn) then also plug wires. Broke distributor cap and screw mounting bosses on the distributor. Replaced complete Distributor with new complete Delco distributor. Had to take the intake plentom off to get the distributor out. Replaced plentom gasket.
Test ran the engine. Ran great.
Took the truck to Madison (300 mile round trip) to pick up some machines (using a snap-on scanner) coming back the engine started to constantly miss fire on #1 cylinder idling The other 7 did not miss fire. So we changed the spark plug on No.1 cylinder no change. We ran the truck home watching the miss fire on the scanner. When running down the road cursing at 55 mph cylinder 2 would continue to miss fire and cyl 1 will not miss fire. When you step on the gas peddle they would switch Cyl 1 miss fires and Cyl 2 would not miss fire
Any Ideas where to start to look. Thank you for any responce.
