Originally Posted By: racin4ds
If its a VTEC motor and ran hard, thats very normal. If you do lots of frequent 10 min trips, I'd either shorten your OCI to 3000 or use a syn oil.
1st Car: 2000 Honda Civic VP, same engine as yours.
I got the car at 60k and got rid of it at 320k
i did no maintenance other then random oil changes, if i ever remembered it.
@ 310k head gasket went bad and got a JDM ZC motor which was a directly replacement(great idea btw if your engine [censored] out on you)
3rd & Current Car: 1996 Honda Civic LX, same engine as before.
i started doing my own car maintenance, and at one point was burning 1 quart every 500 miles. My oil burning is very random, since i started to top of my oil the moment it would drop from the full dot. The oil sump is only 3.6 quart with filter...I just drove 350 miles to Chicago two days ago @ 90 mph cruising speeds and it didn't burn any oil. I have no idea why it's so random. I actually have a mix of Super-Tech FS 5w30, Super-Tech FS 5w20, and Quaker State Ultimate Durability 5w20 because of the random quarts i had laying around. I have been topping off with the 5w20 FS mix of the two brands.
My suggestion would be to top off your oil constantly with the cheapest oil you can find, and probably a thicker oil (5w40 and 10w40 in cold temperature) and (15w40 in hot temperature).
OCI, since you will be constantly topping off your oil & getting fresh oil in there, i wouldn't change oil until 7500 miles and filter every other oil change. I would use Fram Ultra for it's filtering efficiency & high dirt holding capacity.
Honda suggested Oil Change Interval for this engine in 1996 on the conventional oil of that decade was:
Normal Driving Condition: 7500 miles & oil filter every other oil change
Severe Driving Condition: 3750 miles & oil filter every other oil change
Walmart has the cheapest prices daily
Sam's Club has really cheap conventional oil currently, depending on your location, even cheaper then Walmart and these are in 1 quart bottles rather then the big 5.1 quart bottles at Walmart.
http://www.samsclub.com/sams/valvoline-premium-5w30-12-1-qt/157309.ip?navAction=
12 1-quart bottles for 25.88
http://www.samsclub.com/sams/pennzoil-10...8.ip?navAction=
12 1-quart bottles for 21.78
http://www.samsclub.com/sams/trop-artic-5w30-syn-blend-motor-oil-1-qt/160474.ip?navAction=
12 1-quart bottles for 20.32
http://www.samsclub.com/sams/certified-1...0.ip?navAction=
12 1-quart bottles for 17.48
