2000 Cavalier parasitic battery draw
Waterloo, ON
I picked up a low milage Cavalier for my daughter to use. I have been doing some work on it and noticed the battery going dead. The battery is new, so the PO must have been having the same issue. I have been able to isolate the draw to the Interior dome light circuit. I have removed that fuse and the draw is gone. That circuit has the dome light, radio, and door chime on it, as well as some others I may not know about.
These three items all seem to work fine, so I am wondering how I can further isolate the draw, and also wondered if anyone knows if there would be any other loads on that circuit?
TKS
I have heard things about the delco radios themselves leaking current.
Two fuses lead to said radio, BTW.
could be the bcm, if it has one, but i would unplug the radio first.
try getting a wiring diagram (mitchell on demand?) to see if you are missing anything
Body Control Module? What does that do? I think it has one...
I have narrowed the draw down to my radio. So when unhooked there is no draw. I picked up a radio at the local wreckers and when installed I have the same draw again. The radio works fine. I am sure this car has no sub woofer as its a bare bones model.
I'm totally stumped on this I dont think both radios could be bad...
Why can't both radios be bad?
I don't recall ever seeing a Cav with a power antenna but I've seen quite a few with broken radios.
The issues I have seen with Delco radios of this vintage is that they keep trying to eject a CD that isn't there, draining the battery.
