Had one years ago and was a decent DD. I did the Transgo shift kit when it started the hard 4th gear shifts. I mean hard, like Bang!! Something to do with increased line pressure and the kit solves it. As stated, with low miles you likely won't see that for a long time if the rest of the vehicle makes it that far.
Do the LIM gaskets and keep an eye on the fluid levels often to make sure the other gaskets are good. I have a Regal that sat for 6 weeks after my knee replacement surgery and it developed a horrendous transmission fluid leak afterwards. Not sure if coincidence or sitting provoked it, but I replaced the pan gasket and all is fine.
Be prepared to replace the window regulators at some point. It happened to most all the windows in the Century as well as the Regal as they're the same design if not the exact same parts. The cable is terminated with plastic on the end and it gets brittle with age and one day a window will stop working. They drop and Murphy's Law dictates it will occur during inclement weather. It's not a super difficult job, just inconvenient with no warning.
