2 Ford specs: anything to worry about?
In the shop
Good afternoon folks. Getting ready to change oil in friends 2009 Ford Focus 4dr. QSUD 5w20 meets the one Ford spec, but MS5K meets 2 Ford specs. Anything to worry about if I use QSUD 5W20 in her car?
Thank You in advance
I believe the 945a spec is the API SN one and the 945b1 spec is for the API SN plus spec...
I believe that the B1 specification was the updated spec when SN plus came out... I could be wrong.. though I doubt it
Google search shows jack squat, so found a old thread saying B1 is for LSPI. Oh well, MS5K 5w20 SN+ went in as good enough to meet two old OR new specs, good enough for a 10 year old car with 40k on it
no warranty no worries use whatever, but surely older cars with miles on them should use a xxw30 IMO. i use at least xxw-30 in anything i own or service!
Yep, the -B1 spec is to meet LSPI (SN Plus) requirements.
-B1 supersedes -A.
I doubt a 2009 Focus needs SN Plus (-B1) but won't hurt to use it.
-B1 supersedes -A.
Yeah, MS5K is cheaper than ST oil. Rural Iing has it at $12.79
Either would be fine.
The QSUD also has Dexos1-Gen2 which is probably a tougher spec than the Ford ones which just point to SN or SN-Plus.
The only Ford spec I really chase is 913-D
Owner's manual only refers to Ford's oil specs as a veiled threat to warranty coverage. Otherwise, it just says use an oil that meets API specs.
You can use either. If she has the dreaded dual clutch transmission tell her to get ready to spend money on that.
It's a 2009, so regular transmission. I'll never own a newer model focus with that horrible CVT trans
Dual clutch and CVT aren't the same kind of transmissions. No dual clutch (ie Ford's "PowerShift") until 2011 in the Fiesta and 2012 in the Focus.
