I'm about at my end before I hand them over to the dealer tech's.
04 Escape cuts out and back fires through the intake at idle. Never has died just recovers normally at a higher idle. Replaced alot of vacuum hoses, filters and spark plugs have around 20k. It's fine at every rpm about idle and averages 20+ mpg. Temp doesn't matter.
02 Focus cuts out at idle and does the same backfire through the intake. Problem is it's much harsher and it only happens when it's warming up. At stone cold and fully warm it's fine. And warmer the days the better. Typically tap the gas pedal a few times and it's recovers. I did notice today that with the hood up and the sun shining on the maf which in turn caused it to warm up and only cut out twice. Never cuts out above idle. Everything new from coil to plugs.
What are the odds of having almost the same problem with 2 different cars, the 3rd is just dead (it's almost laughable). Could I of been over zealous in cleaning the MAF's? I did not clean the MAF's before these problems occurred just started randomly. The Escape was better for a short time after cleaning but it came back. No CEL's.. what are those darn things good for?
