1996 Ford 460 V-8 Metric or standard
Lakeside CA and Lake Havasu City AZ
I am installing gauges: Mechanical oil pressure, water temp, volts and vacuum. I would like to Tee the oil pressure and keep the original sender in the loop. Does anyone know if the sender threads are metric or standard so I can obtain the needed adapters while awaiting delivery of the gauges? OBD-1 if it matters. It seems many fasteners are metric, but not sure about senders.
After rereading my original post , it may be confusing. I am asking about the threads in the manifold where the oil pressure and water temp senders will go. Are the manifold threads 1/4" pipe as answered?
