It could be a variety of reasons, but since you have covered the basics with new plugs and wires, I would venture to suspect a vacuum leak, or possibly a bad air flow sensor. You will need to pull the codes from the diagnostic plug using an LED and resistor plugged into the B+ and FEN terminals, and ground the TEN pin. Turn on the ignition to on, and watch the LED for the codes.
