I'd like to run an odd problem up the flag pole to see what you guys think ....
While tuning up a friend's 1993 Dodge Intreped I encountered a problem that I've never seen.
The car has 120,000 or so miles on it, and probably has not followed a strict maintenance schedule, just from looking over the engine bay.
Before the tune up, the car cranked & idled just fine. Standing at the rear of the car, you picked up a pretty strong "raw fuel" smell. Inside of the tailpipe was dark & sooty.
Upon pulling the spark plugs, the driver's side of the engine's plugs looked perfectly normal. Pulling the passenger side of the engine, all three plugs were black with a fairly dry soot. Cylinder 1 spark plug was worse than the other two, almost completely fouled. But all three on that side was in very bad shape.
Another observation, the engine oil was jet black and had a slight fuel smell to it.
Again, the car started fine & idled smoothly before this tune up. I also cleaned the throttle body (unsure if it's ever been cleaned before) and it too had alot of rich, black buildup inside the TB.
The spark plug issue on one engine bank only baffles me. Any thoughts out there?
